where is the memcal
Old Jul 2, 2001 | 06:32 PM
87ColdAirIroc-Z's Avatar
where is the memcal
i bought everything to burn chips and now i cannot find where to solder the zif too i am so ******* mad. where is the memcal??
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old Jul 2, 2001 | 06:49 PM
Brent's Avatar
The blue piece is the memcal.
Old Jul 2, 2001 | 06:52 PM
where in the car is that??
I would like to get this done tonight so please help asap...
[This message has been edited by 87ColdAirIroc-Z (edited July 02, 2001).]
Old Jul 2, 2001 | 08:18 PM
CanadianBeast's Avatar
It is in the dash where you would expect the glovebox to be. Crawl under the passenger side of the dash and look up. You should see a whole bunch of wires leading to two connectors plugged in to the ECM unplug these connecters, then remove the two screws that hold the ECM UP and it should fall out. Once the ECM is out remove the two screws that hold the little cover on and you should see the same thing as in the picture above. There are two little clips on either end of the memcal that hold it in, unclip and pull the memcal out. Now remove the blu cover and you'll see the eprom and the two smaller proms soldiered to the memcal.
If you are planning to unsoldier the old eprom and soldier in a ZIF, take your time. It's real hard to soldier in those little holes. Once done check and recheck your connections. Then check them again. I had to resoldier mine three times before I got it to work properly.
Good Luck
Old Jul 2, 2001 | 09:35 PM
Thanks.
88SS6SPEED
Nov 11, 2015 07:05 AM
lethaldomestics
Sep 21, 2015 01:18 PM
RyanJB
Sep 2, 2015 01:27 PM
Keith5
Aug 27, 2015 04:37 PM
