"scan tool" for V6
Old Aug 29, 2006 | 10:04 PM
Belker's Avatar
"scan tool" for V6
I need someone to help point me down the right path. I have a car ('91 Camaro), a computer (WinXP), and a few weak brain cells. I want experiment with a "scan tool" to see the data that my ECM utilizes (and hopefully better understand how my car works) and I want to do this as cheap as possible.
I do not want to do any tuning or programming at this point.
My first problem is that I have a V6 3.1 liter MPFI and most of the info that I've been reading specifically refers to V8 TPI. What is different about my V6 setup? Are there any free programs like WinALDL that work on my V6? What ECM do I have and what mask?
Any help or advice would be greatly appreciated.
Old Aug 29, 2006 | 10:48 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ummmmmmmmmmmmmmmm
Read the stickies up top and follow appropriate links
Searching is another good idea.
thank you
Old Aug 30, 2006 | 01:54 AM
Belker's Avatar
(smart remarks to this suggestion omitted)
Old Aug 30, 2006 | 02:28 AM
Belker's Avatar
For a '91 3.1l camaro is the ECM bit rate 160 bps or 8192 ? I'm guessing 8192 but would like some verification.
Also, I guessing my car has a 1227730 ECU and $88 mask (not $8d). Is this correct?
Old Aug 30, 2006 | 08:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
8192, yes & yes.
Look around for TunerPro and the appropriate ADS file.
RBob.
Old Aug 30, 2006 | 09:43 PM
busta9876's Avatar
Car: 1967 C10 Pickup
Engine: LMM Duramax
Transmission: 4L80E
This might help you out.
I have a 1990 Chevy Cavalier that ran on the $88 MASK. I used a 1993 Sunbird 3.1 PROM as a base for my custom chip. it is a $A1 mask, which is supported by FreeSCAN Andy Whittaker's Home Page
It would be interesting to see how close they are.
is the 91 3.1 Camaro a DIS motor or does it have the distributor?
If you could read you stock $88 I could compair it to my stock $88 cavalier code, and maybe reverse engineer a Sunbird 3.1 $A1 to work.
Ohh yeah, almost forgot, a long time ago when I first built an ALDL interface, EFI Live v4 worked on my 90 cavalier with $88 mask. There was a free file defenition for 1990Z24 that came with it, might try that.
Old Aug 31, 2006 | 01:56 AM
Belker's Avatar
RBob, thank you for your help and confirmation of what I have in my car. I'll look into TunerPro.
busta9876, thank you for responding. A '91 3.1 Camaro has a distributor. I'll look into FreeSCAN & EFI Live. I assume you are looking for a Camaro $88 so that you can compare it to a Cavalier $88. I'm pretty clueless right now, but if I find anything that can help you I'll try to send it your way.
Old Aug 31, 2006 | 07:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The BIN AZTY is all over the net. That is the latest and greatest '90-'92 3.1l MPFI f-body automatic calibration.
RBob.
Old Aug 31, 2006 | 08:17 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
a few major differences
Initial Spark Advance :
F-Body = 9.4 Deg, Cavalier = 59.8 Deg
Initial Time Out Spark Bias :
F-Body = 0.0 Deg, Cavalier = 35.2 Deg
Main Spark Adv vs MAP vs RPM
I noticed the F-Body tables have up to 11 more degrees of timing in medium load 45-75 kpa all way up rpm ranges
VE Tables are pretty close, only about 5 ve or so higher on F-body across the table.
I am in the process of trying to make $8D work on my 90 Cavalier 3.1 MPFI. The 8D has a constant Max Spark Advance 41.8 is stock for AUJP. The $88 Constants does not have the MAX Spark Advance slider, so not sure how to adjust this for my use.
Anyone know what the Initial Time Out Spark Bias does?
Old Sep 1, 2006 | 10:54 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
this is an interesting find for me as I also have a 91 v6 camaro. I am trying to learn tuning. I'm making some progress but I'm still a little lost on some things so maybe I can learn something from this thread! I've got a lot of engine mods on mine so I definitely need tuning!!
Old Sep 7, 2006 | 02:59 AM
daves12secV6's Avatar
can somone point me to a bin for the 92 v6 (3.1) i downloaded one found in the stickeys uptop.but it seems messed up.
Old Sep 7, 2006 | 08:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The one at this link is good:
My 85 Z28 and EPROM Project
It is the 92 Camaro AZTY down near the bottom.
RBob.
Old Sep 7, 2006 | 07:57 PM
thnx RBob
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Corry
May 31, 2001 08:52 PM
Mark305TBI
Jan 28, 2001 11:20 PM
