O2 vs WBO2
Old Aug 31, 2006 | 11:47 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
O2 vs WBO2
I know the best people to answer this is on this board.........
Running a NB O2 on LH side an a WBO2 on RH side and I get diffrent values from them. I have checked for leaks and have changed headgaskets 2times and completly rebuilt the engine with new block and a diffrent cam, same results... Swapped side on the injectors, swapped injector drivers between the sides ( I have 2 running 749 p/H mode) nothing helps so I thinks its the sensor fooling me.....
But if I stand at
idle and activate BLM ist going down to 104 and WB= 15.5
Idle with BLM locked WB is 14.7
Have checked this with swapped drivers between the sida, results the same...
And if I drive say 50mph BLM locked
AFR= 14.7 and O2mV 20-100mV and I get a code 44..........
Why is WB AFR 14.7 at idle rich according to NBO2( BLM 104) and when I drive WB AFR 14.7 is very lean?
Its a heated AFS-74 sensor, not too old either........
69 Ghost
35
Apr 24, 2006 04:52 PM
CriSSes
Jan 3, 2006 02:34 PM
91L98Z28
19
Feb 26, 2005 01:24 PM
junkcltr
Mar 5, 2004 10:36 PM
