PE Fuel ration
Old Jul 31, 2001 | 03:00 PM
BenDoe's Avatar
PE Fuel ration
I checked the archives and couldn't find anything. Question: What are you guys running as your PE Fuel ratio. I have a friend that said 10% rich is the best.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218, 187 head castings with bigger valves, self-burned eproms.
Gained 20HP by porting and polishing my EGR passage.(some people take this seriously)
All work done by myself, and proud of it!
Find a .bin on the internet and want it burned? I'll do it for you!
Old Jul 31, 2001 | 07:28 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I have mine set to 14.7, that is according to what someone has told me on this board. I know I should have been adjusting Acceleration Enrichment instead... can't tell you how exactly, yet.. still working on it.
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.50@ 97 with carb... now converted to TPI
Old Aug 1, 2001 | 07:36 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Whoa, you guys are talking about 3 different things. SlowTA has his air-fuel ratio (AFR) set to 14.7, which is best for emissions and how most engines are supposed to run. He changed his AE to give his engine more of a "pump shot" to cure the lean condition he was getting at throttle tip-in.
BenDoe is looking at the Power Enrichment, specifically how much the AFR is changed when the ECM goes into PE (usually abot 50-70% throttle). 10% rich gives you about a 13.4 AFR, which is still a little lean for best power and torque. I forget which one is which, but best power and torque are around 12.8 to 13.0 AFR. Of course, with our wonderful computers, we can dial in the PE for different coolant temps and throughout the whole RPM range. BTW, your curve should match what the engine needs and will not just be a certain % change over the entire rev-band.
Greg Westphal
'87 IROC 355TPI/A4
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
