Should i order chip for Lg4 orL69?
Old Aug 1, 2001 | 01:51 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I have a Lg4 car.I plan on doing mild mods
like exhaust performer intake maybe a mild cam and a 3:45 9bolt rear.I also have an L69 aircleaner for this car also.I Plan on using
These parts later on a 350 when the 305 tires
out.What Prom should i order?(
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
Old Aug 1, 2001 | 01:57 PM
Old Aug 1, 2001 | 02:28 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Wow, you are upset that no one has responed in 6 minutes?
Actually, this type of question is not really Prom BURNING related and it will most likely get locked. But I will leave it open so others may give some response, but it will probably be locked by the end of the day.
FYI, we generally lock posts when someone asks about "purchasing eproms or difference between various eproms". Those are more "Aftermarket Board" questions and better served over there. This particular question really has nothing to do with Prom BURNING per se.
Regardless, if I am correct about your car, you have a Computer Carb and though my knowledge is limited about them, the CCC eprom is primarily concerned about timing. The fuel is primarily controlled by mechanical methods within the carb itself.
The problem with the CCC type eprom is it is one of the "oldest granddaddies" of eprom generations and there really isn't too much available for them. That is why so many guys just convert the whole thing to a mechanical distributor.
Old Aug 1, 2001 | 03:10 PM
Thanks glenn.I was just practicing the emotions.I will look at topics a little more to make sure im in the right place thanks!
Old Aug 1, 2001 | 03:40 PM
Car: Death Mobile
Engine: 666 c.i.
You COULD consider converting to TBI. TBI controls a lot more than a CCC and the TBI is fairly well hacked. Properly done, I see no reason why a person cannot make a TBI perform as well as a carb and have the better driveability and gas mileage that TBI offers. Best of all, it is fairly inexpensive (when compared to MPFI).
I know that if I was to get an older carbed engine, I would seriously consider converting it to TBI because of the other factors (driveability and gas mileage). Any loss in performance (which I still believe that TBI can be made to perform equally well), I would compensate with some other modification...such as cam, heads, intake manifold, exhaust etc.
Old Aug 1, 2001 | 05:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 86 sports coupe:
</font>
Get the instruction manual for the ZZ3 engine retrofit. It has all the parts numbers, ecms, etc that you need for a CCC. Then get Doug Roe's Q-Jet Book.
Tune as necessary <g>
dimented24x7
Sep 17, 2015 06:58 AM
webeeZ28
Sep 14, 2015 12:00 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
