i need help with crossing out gm computer
i have an 89 firebird with a very modified 350 and tbi. damn thing is ive still got the 305 computer in it and i know its not running nearly up to par. will the computer out of a 350tbi truck work as a make shift computer with better tables until i can get a real prom done. also what if any other computers could i scavenge from a bone yard that would be an improvement.
thanks
jptaylor
1989 formula
jasper 350 (punched to 397ci)
trick flow twisted wedge heads(2.02 intake and 1.72 exhaust)
1.6:1 roller rockers
jacobs omni magnum ignition
isky cam
flowtech jethot coated headers
mufflex 4" mandrel stainless exhaust
no cat
holley 670
open element
custom fixed headlights
97 formula interior
macewen white faced gauges
3.42 posi rear end
baer racing 4 piston calipers front and rear
underdrive pullies
hard wired cooling fans
www.geocities.com/jptaylor2/FIREBIRD.html
IN EVERY RACE THERE IS A VICTOR AND A VICTIM, YOU LOOK LIKE A VICTIM!!!
thanks
jptaylor
1989 formula
isky cam
no cat
holley 670
open element
97 formula interior
3.42 posi rear end
underdrive pullies
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If your signature has your current mods in it NO ! You will need a custom prom for sure.
A 7747 from a trk will work temporarily (no MAT) on a stock engine.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
