TPS voltage ??
Old Aug 15, 2001 | 06:33 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
TPS voltage ??
I have the PTS set at .54 volts at idle, but at full throttle it reads about 4.3 volts. When I use Craig Moates software the car idles at 10% and full throttle is about 85% throttle. Is this a sign of a bad TPS, I can't find any information about what it should read at full throttle. Also if it is bad, would it cause a bog at tip in? It sounds like a good theory to me!
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.50@ 97 with carb... now converted to TPI
Old Aug 15, 2001 | 06:50 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by slowTA:
</font>
The first thing to do with check the mechanicals of the situation. Does the gas pedal even open the throttle all the way?.
then, why is the inital adjustment that high?.
Have you set the min idle speed?.
Check the intial timing?.
Generally if all that is correct then you'll have resolved the problem.
Old Aug 15, 2001 | 07:49 PM
slowTA's Avatar
Car: '88 Formula
Yes, the gas pedal opens the throttle right to the stoper, min. idle is set, timing is at 6 degrees. So apparently this isn't a general problem. Just my luck.
What does your throttle postion read when using Graig's software.. or whatever software you are using?
Old Aug 16, 2001 | 07:17 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It's a problem with Craig's software. He's calculated %TPS by using 0 volts as 0% throttle and 5 volts as 100% throttle, but that's not how GM does it. Bruce, any idea on how it's supposed to be calculated?
Greg Westphal
'87 IROC 355TPI/A4
Old Aug 16, 2001 | 05:12 PM
slowTA's Avatar
Car: '88 Formula
So everything is normal then.... thats great! Thanks for hte help Greg!
Old Aug 17, 2001 | 01:12 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The answer to your question is:
TPS voltage at idle should be .54 volts.
TPS voltage at WOT should be 4.49 volts.
A + or - .07 volts is acceptable.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Aug 20, 2001 | 08:04 PM
chooch-88formula's Avatar
So if I'm reading .7 + a little .... that would be too much for Idle?
88 Formula WS6 TBI 350
The other hobby
http://home.rochester.rr.com/hoscar/indexn.html
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
