AFR Tuning with WB02
Old Sep 22, 2006 | 09:05 AM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
This may be a stupid question but here it goes.
I am tuning my 84 Vette and I have EBL with Ostrich and a WB02. I am straightening out my idle (thansk RBob) and so forth.... After much reading and thinking I have a basic question. While tuning my PE/AE and VE tables should I be targeting a AFR 12.7:1 as read from the WB02 or 14.7:1. I ask because at idle with everything warmed up the exhaust is stinky (rich) at 12.7:1. The exhaust is new and the Cat is as well.
Old Sep 22, 2006 | 11:09 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
This is just my $0.02 worth. I am sure others will have different thoughts-
If it is running in closed loop, tune for 14.7:1 in your part throttle areas. Use your PE tables to get you down around 12.3-12.7:1 for wide open throttle. Idle can tune for 14.7:1. I have seen even slightly leaner mixtures at idle, it will depend on what the engine likes.
Old Sep 22, 2006 | 11:12 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Don't forget to disable CCP. Are BLMs and INT locked at 128 also?
When I did my O/L tuning I used 14.7 although I have modified that to 14.2 based on 10% ethanol here in Illinois.
Old Sep 22, 2006 | 06:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You tune to make the engine happy.
There are no magic numbers.
Timing will also influence your indicated AFRs.
Again, tune for the least amount of timing consistant with max performance.
With that said:
A mild engine does well with 14.7 at idle, and light cruise.
PE uses the richer AFRs for in cylinder cooling, the hotter the inherit temps of your combo, the more fuel is needed. I've seen AFRs from 10.6, to 13.2 at PE being used successfully. For AE again depending on combo, a slight leaness to just a tad richer then Stoich can work.
ULTM8Z
Oct 2, 2015 01:25 PM
