"Minni Ram Pump Shot" Tuner Cat 6e need help
Old Aug 25, 2001 | 12:29 PM
justinjjf's Avatar
how can I take care of the minni ram stumble problem.......will engaging PE sooner help?
form a dead stop I jump on it and it falls on its face..... the o2 readings go extremly low....so I am asuming its a lean condition....does anyone have any tips for me
thanks
Old Aug 25, 2001 | 01:29 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by justinjjf:
</font>
I had to take the timing down to -6 below 2,000 rpm with my FBod to get it to leave clean. Try taking a bunch of timing out below the stall / flash speed of the converter. You'll proably go way down in % TPS for PE. To get the GN to leave cleanly I have the first step of PE at 11%, then the next one at 18%. Timing is like 12d til 2200 rpm.
AE enrichments are just about a lost resort for me.
Old Aug 27, 2001 | 07:17 PM
89vette's Avatar
Like I already told you in an email, the Tunercat ECM definition file does not have the pump shot tables. At least the version I have does not. GMEPro has all of them. You can buy GMEPro for from Terry Kelly. Do a search to find his email address. Maybe write to Tunercat and ask him to include them. Of course you can do what I'm doing and ditch the Miniram altogether in favor of a ported and extrude honed SuperRam.
Jason
89 Six Speed FX3 coupe
7730 SD Conversion
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
Old Aug 28, 2001 | 07:29 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
</font>
I have encountered situations where the SuperRam also exhibited a minor form of this off-idle lean problem. What I can say is that my '90 (730) seems to run just fine with the MiniRam and a big cam after tuning. I really don't have any complaints about how my car feels at part throttle or the transition to WOT.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Aug 28, 2001 | 10:05 AM
89vette's Avatar
Yea I know there are those that like the Miniram. I had a SR on my car before the MR and had no problems at all. The very day I put the MR on I had problems. Trax, if you drove my car the way its tuned now you would think I'm crazy for switching. My tip in problem is only present after coasting in decel mode and then adding throttle. At that point is where the tip in hesitation is now. The swap is just something I have to do. One positive thing about the MR is that I learned a heck of a lot about tuning.
Jason
Old Aug 28, 2001 | 11:05 PM
leirch's Avatar
Jason,
Did you ever figure out that popping through the exhaust when you shifted? I experience the same problem, I was running a auto chip with my changes but have since switched over to a manual chip with my changes and it works MUCH better but for some reason it pops when shifting, but only sometimes.
About the MR, I don't have any experience but the SR does work pretty well. Just remember, when you switch back, your going to have the PITA install of the SR. I'm ripping my motor out this winter so I can get a ZZ4 shortblock to put all of my goodies on(missing the number 6 cylinder still). BUT, I'm going to cut my injector harnesses back before the SR and put a weather tight plug on it so that I can pull the motor without having to take the SR off to unplug the injectors.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Aug 29, 2001 | 08:31 AM
89vette's Avatar
Leirch, Yes I fixed that. I was using an auto bin and switched to a manual bin. The base bin I'm using is the 90 Vette Manual L98.
Jason
Old Sep 3, 2001 | 09:06 AM
Bowtie8's Avatar
Regarding the Pump shot
I am running a 58mm witha miniram and had a stumble problem with my 6spd. I found that raising my pump shot to 100% on the first three parameters and upping my timing on my KPa map fixed the stumble problem. The diacom was also saying way lean on the tip up which is why I added fuel there. Granted with the 6spd it may be more forgiving than the autos. Just thought I would throw it out there.
[This message has been edited by Bowtie8 (edited September 03, 2001).]
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
