GM MemCal part# 's
GM MemCal part# 's
Does anyone have a source of the 86-92 GM MemCal part numbers? It would be so much easier to oder a new MemCal, if I had a GM part number. The parts guy's just don't now much unless I can provide part numbers.
88 GTA 350/700 R4
88 GTA 350/700 R4
<font face="Verdana, Arial" size="2">Originally posted by CLEE:
Does anyone have a source of the 86-92 GM MemCal part numbers?</font>
Most if not all of these have changed over the years; the p/n may still be the same, but the BIN has changed.
F-bodies must be similarly numerous.
Best bet - look up your present BCC at http://holman.cs.uml.edu/~sdurphey/bccfind/ and try ordering the p/n indicated. (You can check if it's still available at http://www.gmpartsdirect.com/).
I used to work GM parts. If they can't find a Memcal for you they aren't worth a damn.
Find a new dealer.
You'll want check pricing with Dal @ Vandevere Olds or GMPartsdirect like was mentioned. THey have much lower prices.
Find a new dealer.
Go to https://www.gmotors.com/request_form.asp and fill out the request form with all the information you have on the ECM and current memcal. They should be able to give you the latest part number.
BumpaD82
Feb 26, 2016 02:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
