CM Software Question...
Old Oct 7, 2001 | 09:04 PM
IROCKER's Avatar
I posted this in the ECM forum, but this looks like the place I should have posted it, so here goes.
While I finally got my cable from AKM electronics soldered together last night and tried it out this morning with Craig Moates' ECM software and both of them work great! My question though is how do I know what the acceptable values are? My car is running good right now, so I could use the values I've got now...but I'm wondering if someone has a list of the expected values, from GM or something. I hope that makes sense...There's just so much data I just want to make sure I'm deciphering it properly. Some of the values make sense to me and others I don't have a clue what I should be looking for.
And Craig, if you're out there...First off, great job on the program and thanks for refering me to Andrew at AKM. Do you have a listing explaining all the different fields? Some of the field names are the same but show totally different values...like the Engine RPM on the first page and the Engine RPM on the 4th page, and other stuff like that.
Thanks in advance for your help...
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Oct 8, 2001 | 09:52 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Irocker,
I went to my local Barnes and Noble, and purchased a Tuned port book, it has some useful information, however, some of the best information I have has come from www.alldatadiy.com, however it is a subscription service.
Cheers
Richard
Old Oct 8, 2001 | 12:07 PM
IROCKER's Avatar
Thanks...I've seen a couple of books for tuned port at the stores...Do you have any specific titles I could look for?
1987 Camaro IROC-Z
2001 Sunfire GT
Old Oct 8, 2001 | 01:17 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
When I go to the house tonite, I will look up the book for you!
I will try to post some 'normal' numbers for you as well.
Watch this space
Cheers
Richard
Old Oct 8, 2001 | 04:43 PM
new2tpi's Avatar
One bit of information I can't seem to find in Craig's software is the number of steps the IAC is at. I know this is probably simple, I just don't see it.
Thanks in advance
Old Oct 8, 2001 | 05:24 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
The numbers on page '1' are 'raw' byte values. There are some calculations required to render some relevant data from the raw values, such as RPM and MPH, which often require a short equation and combining byte values in some way. Like the IAC counts and such, please let me know if there are 'calculated' values (ie. values which can be derived from the 'raw' byte values on pate '1') which are not shown on Page-4 which you have an interest in.
The calculations can be done by you in Excel or something after-the-fact from the raw byte value collection, but it makes your life easier if I put the calcs in the program up front...
Once again, if you see a need for values that are not shown, drop me a line saying which ones. I'll let you know where they are or chalk them up for the next revision....
-Craig
Old Oct 9, 2001 | 12:56 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I could go for an IAC count output......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Galaxie500XL
Oct 1, 2015 01:05 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
happyhapka
Aug 15, 2015 04:42 PM
