MEMCAL V6/V8
Old Oct 15, 2001 | 08:03 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
MEMCAL V6/V8
I've read almost every question I can find on obtaining salvage yard memcals and came to the conclusion that some people believe the cylinder select is wired into the non-PROM part of it. I'm going to try it anyway and see if they work but. . . If so, this won't work for a V8 TPI, right?
http://cgi.ebay.com/ebaymotors/aw-cg...790555&r=0&t=0
http://holman.cs.uml.edu/~sdurphey/b...b.cgi?BCC=aych
I guess you can tell I'm into burning for three days and already I'm looking to upgrade from MAF to speed density!
Thanks in advance!
_ ___ _
SMasterson
Old Oct 16, 2001 | 01:15 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You're right it won't because the limp home mode in the other part is for a V6 and also it has the knock sensor in it for the V6.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
88SS6SPEED
Nov 11, 2015 07:05 AM
lethaldomestics
Sep 21, 2015 01:18 PM
RyanJB
Sep 2, 2015 01:27 PM
Keith5
Aug 27, 2015 04:37 PM
