interface cable Q's
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
interface cable Q's
In the two transistor type there is no connection to the "B" pin on the ALDL but when using a MAX 232 there is. Isnt it needed?? why?
Is the MAX 232 "version" better than the other one or?
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
I use a simplified two transistor interface (one transistor)
Sometimes the 10k ohm from pin A to pin B is not included in the interface. That resistor is used to change the ECM mode of operation and is not really a part of the interface.
No connection - normal mode
10k ohm - ALDL mode
3.9k ohm - Factory test mode
short - diagnostic mode
Many ECM's output data in normal mode too and then you probably want to use that mode.
Jonas Bylund
[This message has been edited by JoBy (edited November 21, 2001).]
10k ohm - ALDL mode
Jonas Bylund
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
