LV8 load, how to get it
Engine: 5.0L tpi 85, 6870 ecm, 1$F
Transmission: T350
My head is spinning from the stickies. i'm trying to apply the 165 info to my 870 ecm. Should i be alble to log LOAD or do i have to manually calculate it?
Car: check
Engine: check
Transmission: check
It doesn't look as though the LV8 is included in the data stream. The value can be calculated from the RPM & airflow. These are included in the data stream. The LV8 value is basically the airflow divided by the RPM.
RBob.
RBob.
Transmission: T350
RBob,
thanks for you reply, i have been reading some of your other post where you show the calculation as being:
LV8 = (((DRP * gms/sec) / 256) * Scalar) / 64
i'm getting #'s bigger than 256 using this calc. for example my RPM is 2625 & my airflow is 23637 from tunerpro. I dont know what the units are however, i assumed it was 236.37g/sec, but that could be where i'm off base.
does anyone know what the units of airflow is coming from tunerproRT on an 85 870 ecm?
thanks for the reply
Transmission: T350
where do you find what is included in the data stream? i've data logged bytes by editing the aldl file that are not included in the basic aldl file & there is additional data, but i dont know what it is.
Car: check
Engine: check
Transmission: check
RBob,
The DRP is the inverse of RPM. For a V8 it is:
DRP = 983040 / RPM
So 2625 RPM is 374 DRP
The airflow is gms/sec * 256, for 23637:
gms/sec = 92.3 = 23637 / 256
For a scalar IIRC ARAP uses 80, so we'll try that. Using the equation from above:
LV8 = (((374 * 92.3) / 256) * 80) / 64
is: 169 for LV8
RBob.
RBob.
Transmission: T350
thanks Rbob, i really appreciate you helping out a beginner.
the airflow = gm/sec * 256 was the part i was missing. thanks much, now i can create a spread sheet to import into that will calculate the load for me.
much appreciated!!!!!!!!!!!!
efiguy
Sep 27, 2015 01:30 PM
