EBL 1.8 Smoothing
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
EBL 1.8 Smoothing
RBob,
Playing with preferences to see effect of smoothing on NEW bin. I ran the same datalog and beginning bin thru EBL using a 12 smoothing factor and then a 2. The resulting VE Corrections table however for both was exactly the same. Should I see a difference in the VE Learn Corrections in % screen or not?
Car: check
Engine: check
Transmission: check
This is a 'it depends' answer. If the VE table is already close to being smooth, there will only be a small amount of additional smoothing.
RBob.
RBob.
