idle-IAC questions....
Old Mar 18, 2007 | 08:06 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
hi all..
still fighting with idle problems
the IAC park position is 160 counts....
when my engine is cold, its at 160, and still its not enough air to get a stable idle...
min IAC is 40 counts
what would happen, if i define 120counts as park position, and open the TB a bit more? would the counts then go up, or will 120 still be the limit?
hope you can help me
regards
Reinhold
Old Mar 18, 2007 | 09:09 AM
ULTM8Z's Avatar
I would simply set you desired idle speed in the calibration. Then just open your throttle blades to get the number of steps you want (which I would recommend 0-10 in park/neutral).
Old Mar 18, 2007 | 09:20 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
what is the thing with the min. IAC counts?
are they fixed, or are they a function of TB opening?
e.g. when i open the TB , will the min.IAC counts go down?
thanks
Old Mar 18, 2007 | 10:48 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Upon start-up the IAC should be at the park position count.
Upon, RUN, that should stay the same, or slightly ramp to a lower number.
If 160 ain't enough, then you have a poor combo of IAC pintle, too low of min idle setting, incorrect amount of timg for a cold engine, or a mechanical issue.
First try opening the min idle screw say 3/4 of a turn.
BTW, start with a clear head, a clean sheet of note book pager, and notes with * A NEW BEGINNING*. It sounds like you've been chasing things, rather than analysising them. Taking detailed notes of trends, ALWAYS works.
Old Mar 18, 2007 | 05:44 PM
ULTM8Z's Avatar
that's basically the number of counts (steps) it takes to idle the engine over-and-above what's coming through the throttle blades. It varies with temperature (more counts needed at cold, less at full operating temp).
Completely a function of TB opening. If you closed you TB completely, the max or 160 probably wouldn't be enough. If you opened your TB completely, the steps would go to zero as the ECM attempted to lower the idle back to what was specified in your cal.
[/QUOTE]
Yup.
Old Mar 20, 2007 | 04:00 PM
boatderek's Avatar
Re: idle-IAC questions....
first, shine a flashlight into the idle air passage and see where the iac actually is. mebbe the ecm is trying to open an iac that ain't opening. you might wanna get or borrow another iac to plug in to see if the ecm moves it, then screw in place to run motor while you check existing one.
Old Mar 21, 2007 | 02:47 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
hi!!
the IAC works for sure, its nice and clean, and you can feel it working...
i think, will go through the reset procedure and hope it fix the problem
thank you
