TunerPro RT acting crazy
Old Mar 25, 2007 | 07:33 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Delete this....figured it out.....
Apparantly, TunerPro doesn't like whole values so it doesn't save them. Please delete as I have figured this out. Thanks!
Old Mar 26, 2007 | 10:30 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: Delete this....figured it out.....
What was the problem and what did you figure out? TunerPro likes whole values whole bunches. But only if you tell it to like them.
Old Mar 26, 2007 | 11:04 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Well, in my spark advanced table....I just wanted whole values so that it was easier to read tuning it. So, I did in the toolbox, absolute fill in with value....whatever it was, clicked on the cell/cells I wanted it at and executed. Saved it. Closed it then opened it up to see if it saved and it didn't so after I posted my topic, I just tried to save it with another value and it saved so if there is a trick I didn't use, that would be very helpful.
Old Mar 26, 2007 | 11:43 AM
Mangus's Avatar
Transmission: T5WC
Re: TunerPro RT acting crazy
Set the number of decimal places in the XDF item (i.e. select the table in the list and hit F2) to 0.
TunerPro converts the raw binary using the math specified in the XDF and rounds to nearest resolution allowed by the raw binary data. For instance, if the factor is 1.5 and the bin is data is 1 (bin data will always be a whole number), then you'll get an output of 1.5. If you put 1.6 in a cell and try to save it, it will round to 1.5. 1.7 rounds to 1.5. 2.8 rounds to 3 (which gets saved as 2 in the raw binary, since 3/1.5 = 2). Clear as mud? =)
This is by design. In gerenal, though, you wouldn't want to round your spark/fuel tables to the nearest integer. You'll lose a relatively significant amount of resolution by doing so.
Old Mar 26, 2007 | 01:48 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea.....crystal! Thanks....never knew that existed.....interesting stuff in there.
Yea I know but since I was starting out I figured this would be easier to begin with whole numbers and then put decimal values in later to get the max out of it. Or would it?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
