Newbie question!!
Old May 14, 2007 | 11:22 PM
90c350's Avatar
Newbie question!!
Im just wondering if someone can tell me what table or what column to use to change my bpc setting for a higher fuel pressure??? Im playing with tunerpro right now and I currently have 61lbs injectors at 20psi. This should work out to about 101lbhr right?? I think that my bpc should be set at about 82??? But I cant find where to set this?? Its a 7747 ecm and Iam trying to get the anlu bin to run right. Any help on what table I should be looking for or what it would be called in tunerpro would be greatly appreciated. As Im sure you realize Im a little rich right now. PLease help.
Old May 15, 2007 | 12:44 AM
91chevz71's Avatar
Re: Newbie question!!
Here's my old L05 ARJU.bin and $42.xdf-
these are the only two BPW items I could find, one in constants(BPW constant) and the BPW vs airflow vs EGR table on the bottom.
I'm sure someone else will pipe up and help further
Mike
Old May 15, 2007 | 12:11 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Edited....
Old May 15, 2007 | 01:33 PM
Ronny's Avatar
here is a calculator: http://www.users.bigpond.net.au/ben_...ctorsizing.xls
Old May 15, 2007 | 01:35 PM
honken's Avatar
Car: El camino 70 ss
Engine: corvette lt1 94
61 lb/hr at 20psi set the bpw constant to 104.2.
The injector flow at 20psi is 82.25 lb/hr and support approx 280hp.
On my xdf its the BPW Const for EGR off.
Old May 15, 2007 | 01:38 PM
Ronny's Avatar
61 at 20 comes to 75.66 lbs/hour. or a BPC of 113.0. assumes 2 injectors at 349 CID.
Old May 15, 2007 | 08:12 PM
90c350's Avatar
Hey thanks for all the help guy's but it seems that there is alot of different calculations or different appinions on what everything works out to?? Is there any standard calculations that I can use?? And thanks to those who told me where to look for the bpc table's. I will be getting the ebl soon and would like to have the calculations figured out for that before I run it. THanks
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
