Winaldl help please...
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Just today, the Battery voltage in my datalogs shows 0 volts?
I am using the autoprom with tunerpro and winaldl for datalogging.
So far I have been tuning with good results. The engine runs totally fine, but the volts still show 0, and the IAC inhibit flags checked.
Does anybody know what this could be? I have a 7747 ecu in a 91 K2500.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Winaldl help please...
Hey Randy
Conversion for Battery voltage is not performed correctly. It should be Byte 16, raw data * 0.1 and in your case 142 * 0.1 = 14.2 volts. Which is about right. Check if conversion formula has been altered.
This is looks like WOT attempt???
//RF
//RF
