What now??
Old Jun 7, 2007 | 08:26 PM
90c350's Avatar
What now??
Just looking for some advice. I have just got my first chip burned and the moates adapter in. I set my base timing to 8* and changed my bpc to 113 do to 20psi and 61lbs injectors, I also turned of the egr- non existant. It runs better now and seems to pull past 4000rpm now. Its not rich at idle any more and I can accelerate much better. I dont have my data cable yet so i cant datalog yet. Just wondering what table to adjust for ve and ae and a 7747 ecm running $42??? My combo is as such- 4bolt350 8.5.1 compression/ultimate tbi mods/comp Xe256 cam/ edelbrock rpm air-gap/Shorty-creamic headers 3" exhaust/Msd ignition and 462 heads. I currently have a slight lean pop on accell from a stop or slow roll. And just looking for any more advice on what to tune next. THanks
Old Jun 8, 2007 | 09:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What now??
First thing to do is to get the VE tables into shape. For this will need to data log. Once the VE tables are good then move on to the AE portion, and SA as the AE progresses.
RBob.
Old Jun 8, 2007 | 12:10 PM
90c350's Avatar
Re: What now??
Hey thanks once again RBob! I will hopefully have my cable this week. Just wondering? with the Ve table's do you add table one and two together to get your total ve or is it done differently with the 7747?? THanks again for the help
Old Jun 8, 2007 | 02:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What now??
They are added together for the final VE, truncated at 100%.
RBob.
