Question about using ASM11
Old Jun 8, 2007 | 03:04 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
I have JP's commented source for 8d AUJP, and I'm working on getting it to assemble. The assembler (ASM11) doesn't like the spaces between the operands (ex, L0000 = 0x0000, it needs to see L0000=0x0000).
So there is a switch ( -sp) that is supposed to remove the spaces but doesn't seem to. Does anyone else have this problem, know how to easily fix it, etc without me going through and fixing 2 thousand some odd errors? BTW they are all the same errors, "Bad INHERENT instruction/operand".
Thanks,
Ben
Old Jun 8, 2007 | 04:11 PM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
Re: Question about using ASM11
Hi,
Did you read the thread:
https://www.thirdgen.org/forums/diy-...5&pagenumber=1
Perhaps this will help to find out how to get assemble.
Regards,
Cobra289
Old Jun 8, 2007 | 09:12 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Use the Dewtronics assembler and it goes together without any errors.
Will match exactly.
I think the link for it is in that thread somewhere. If not, a quick Google turns it up.
http://www.dewtronics.com/cgi-bin/asxxxx.pl
Use "-xlosf" when assembling for a really nice "LST file to follow with.
Jp
Old Jun 8, 2007 | 09:52 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Ah, no I didn't see that thread. Sometimes I forget about looking in the stickies. I'll check it out.
Thanks for the heads up on Dewtronics, JP.
edit: Using that thread, spitting out a .BIN file was a breeze once the correct software was had. Thanks again.
Old Jun 10, 2007 | 11:51 PM
Z69's Avatar
Z69
ASM11 is only good for some smaller patch files etc.
Eventually you'll make it choke on something rather simple you want to do and you'll have to switch to another assembler.
It doesn't like to do some things that ashc11 or M6811 will do.
All of which use slightly different syntax for addressing etc.
I had to go back and re do a lot of my patches to get them to work when I switched to the posted relocatable aujp asm.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
