Spark counts winaldl??
Car: check
Engine: check
Transmission: check
Re: Spark counts winaldl??
They are the counts of knock being reported via the sensor and ESC module. The ECM may or may not retard the timing in response to the counts. The counts may or may not be true detonation.
RBob.
RBob.
Anything to be had by using the vortec 305 truck knock sensor with roller rockers?? I've read that the RR's are little noiser and can mess with the stock 350TBI knock sensors. I think I might have some false knock.
Ok thanks alot guys I just wanted to confirm what they meant. Im working on my timing right know and wanted to make sure that I understand the readings correctly!! Im not getting alot of them just a few in more spots than others.
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
