ARAP Hesitation
Old Aug 17, 2007 | 10:51 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
ARAP Tip-In Hesitation
Could I get a few of you guys to look over this data-log and see if you notice anything that stands out to you; this is my first good log and all the information is little overwhelming right now. I have an off-idle hesitation that is very noticeable if I stab it from a stand still (hesitation is lighter when easing off from a stop), but once moving all seems to be pretty kosher. There is also a code 23 that has been fixed, but I forgot to clear the codes. The .bin is basically stock (changed injector constant to 24# for LS1 injectors, base timing set to ~9d, VATS unset).
Data-log was done with AutoPROM and TunerProRT.
I'd really appreciate if someone could point out some key points in the .bin and data-log and which direction I should go.
Thanks,
File Type: zip
Old Aug 24, 2007 | 01:20 PM
Duts87ss's Avatar
Re: ARAP Tip-In Hesitation
Did a little reading. Looks like I'll start with modifying "Minimum Delta TPS for AE".
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
