Hows this sound?
Old Aug 31, 2007 | 08:46 PM
nbays1975's Avatar
Car: 88 GTA
Axle/Gears: 10 bolt rear w/3.73 richmond gears
Hows this sound?
I'm ready to start my first chip. Just wanted to run my setup by some of you more experienced guys before I jump in. My engine is a 383 with aluminum edelbrock performer heads, comp cams roller cam (230/234 110lsa), 52mm throttle body, t-5 manual tranny, and 3.73 rearend. From everything I've read, I should use a $6E bin with APYP Broadcast Code. The $6E sounds easier to work with, and the APYP seems like it is appropriate for my setup, especially the cam and heads. Sound Good?
Old Aug 31, 2007 | 10:38 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Hows this sound?
nbays
The only way to answer your question is to try it. Start with idle, make sure that you are getting plenty of fuel. You rather be a little bit rich than lean - watch BLM's.
Ideally, get WBO to dial in.
//RF
BewleyBizzIROC
Feb 3, 2020 09:52 AM
gta90
Sep 15, 2015 04:00 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
BurlyChev
Aug 16, 2015 09:08 PM
