Where can i get a cable?
Car: 92 Z28 Camaro
Axle/Gears: 3.73 posi
I just got a new laptop for when i ship out to iraq but i figured while i'm still here i could datalog my car and tinker around some see what my cars doing.. but my question is where can i get a cable and which one would i need to link my laptop to the car?
what else would i need to datalog the car as this will be my first attempt on this?
thanx in advance for the help
Transmission: 5-speed/T-5
Re: Where can i get a cable?
Moates (www.moates.net) has cables to connect laptops to the car. ALDU1+CABL1 would be what you need for any OBD1 GM up to 1993. Then TunerPro RT to datalog (www.tunerpro.net), this will be the easiest to get to run set-up. For the .ADS file you can download that either on tunerpro.net or more likely to find the proper .ADS for your car on moates.net in the fileman section (link near the bottom of the nav bar).
You could also make your own cable from the many plans that are on the net for such, if your laptop has a serial port. I haven't found any online USB based make your own plans.
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
