6E warm startup idle adder??
Old Sep 13, 2007 | 04:33 PM
Michelob's Avatar
Car: 87 L98 TPI
Engine: ZZ-4 heads, LT1 cam, AUJN Prom
after datalogging with 6E code AUJN and ARAP it looks like there's an ECM commanded idle adder for the first few secs on warm startup of 200 rpm for AUJN and 150 rpm for ARAP.
does anyone know how to reduce these values ?? i think i found a reference to it in line D3CE on the ARAP hac... but not sure how it's calculated with the value of $56 there
; IAC TARGET SPEED vs COOLANT TEMP
; TBL = .08 * RPM
D3AE: LDAA L005D ; COOLANT
D3B0: LDX #$C52E ; INDEX IAC TARGET SPEED TABLE
D3B3: JSR LF3FF ; 2d Lk Up, (No Offset)
D3B6: LDX #$C526 ; INDEX IAC Tables & Params
D3B9: BCLR L00F9,#$20
D3BC: LDAB L00F9
D3BE: BPL LD3C2
; ADD IN AN OFFSETS
D3C0: ADDA 5,X ; 5 STP'S ADDED FOR COLD ENGINE
D3C2: LD3C2 LDAB L00F8
D3C4: BMI LD3C8
; .... else
D3C6: ADDA 7,X ; 0 RPM/12.5, IAC TARGET OFF SET ADDER
D3C8: LD3C8 LDAB L003B
D3CA: ANDB #$20
D3CC: BEQ LD3D0 ; .... else
D3CE: ADDA $56,X 150 RPM/12.5, ADD RPM OFFSET IF HOT
; SPARK RTD ACTIVE
D3D0: LD3D0 ADDA L01B4
D3D3: LDAB L0036
D3D5: BITB #$20
D3D7: BEQ LD3DB
; ....else
D3D9: LDAA #$50
D3DB: LD3DB STAA L0108
Old Sep 13, 2007 | 06:27 PM
Michelob's Avatar
Car: 87 L98 TPI
Re: 6E warm startup idle adder??
ok, it's been awhile since i've done assembly language but as i understand on line d3ce the command is ADDA $56,X
which i'm guessing takes the value at address $56 and adds it to X. sound right??
so where do i find address $56... is that on the chip or somewhere else like the memcal??
Old Sep 13, 2007 | 06:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The value $56 is added to what is in the X register. That result then points to an address. With X being loaded with $C526, the end address being: $C57C
That is in the PROM, which is offset by the ECM to $C000. Subtracting out the offset the BIN/PROM address is $57C
RBob.
Old Sep 14, 2007 | 01:47 PM
Michelob's Avatar
Car: 87 L98 TPI
thanks! that's exactly what i needed... i missed it earlier when i went over the addresses section in the hac.
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
amcnellis
Sep 16, 2015 04:16 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
IROCtometal
Sep 9, 2015 10:01 AM
