DataMaster v351 & APU1
Old Nov 17, 2007 | 12:55 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Just starting, and have been able to start datalogging car
with the full APU1 usb setup. Using the registered version
of TunerPro RT. Was able to datalog about 30 minutes of
street driving and play back. (Very) impressive piece of hardware and software. Took awhile to get everything to
connect and play togeather
Question; Have friend on net who's been at this for awhile
and he is using (DataMaster) and needs logs to read and
explain to me.
Want to D/L Datamaster, (20 datalogs before registering).
Can I run both TPrt & Datamaster on same system without
having to change setting ect ect and not having issues?
I can see now this is going to be a (Patience) project.
Many more questions to come
Old Nov 17, 2007 | 07:56 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: DataMaster v351 & APU1
If you use the AP in "Pass through" mode it works just like an ALDL cable.
You can run TP, DM or ScannerPro without changing settings.
Providing you can get any one of them to work, they will all work.
To make changes and log simultaneously only works with TP and AP.
You can use data tracing feature in TP (Very cool)
Old Nov 18, 2007 | 01:51 PM
jaykar's Avatar
Thanks for reply.
Is Scanner Pro the new update for TunerPro??
Later
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nomar116
Oct 26, 2001 11:19 PM
flinx
Jul 17, 2001 07:43 PM
