PE Questions 6E
Old Jan 4, 2008 | 08:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
PE Questions 6E
So in order to get my head around tuning I am studying the stock ARAP bin.
PE v Temp give +26% through the warmed up temps
but PE v RPM gives +6% at 2800 , 0% at 3200 then -7% through to max RPM.
I would have though you want want to maintain enrichment a little higher even allowing for the TPI limitations.
At the same time the ARAP is adding in 9 degrees of spark at 3200 only.
More spark and less fuel = knock ?
Old Jan 4, 2008 | 11:31 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: PE Questions 6E
16% enrichment will get you to about 12.7:1 A/F. So, there really isn't any "less fuel" going on there, with 19% still in it.
I'm not sure, but I think the ARAP calibrator was trying to get the thing to knock, and then ride the knock sensor the whole time at full throttle.
Old Jan 5, 2008 | 12:01 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: PE Questions 6E
"16% enrichment will get you to about 12.7:1 A/F. So, there really isn't any "less fuel" going on there, with 19% still in it."
So the % numberss are accumulative, so there would be 26 + 6 % at 2800 ?
" I think the ARAP calibrator was trying to get the thing to knock, and then ride the knock sensor the whole time at full throttle."
ARAP timing appears fairly aggressive. I have one knock passing through
3000 that is pulling timing. Have lowered the spark in this area but are seeing more knock now.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
