tuning equipment? ..
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
hey ..
i just finished building my 91 camaro 305 tpi with cam, heads, intake, exhuast, etc .. (5 speed, 305 tpi, 730' ecm, speed density)
and it runs fine for now but i'd like to get into tuning so i can get the rest of the power out of it ..
now ive done some research on buners, aldl cables, chips, ebl flash ..
but could someone put together a list of stuff i would need to start tuning ..
would the ebl flash be good .. or should i get a chip, burner, data logging program, etc ..
any suggestions would help ALOT ..
thanks,
adrian
thanks,
adrian
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tuning equipment? ..
"or should i get a chip, burner, data logging program, etc ."
Buy Mr Moates Ostrich; real time programming ,instant changes and no need to burn chips unless you want to load a hard copy on to your car.
TunerPro RT for tuning / dataloging on a budget ($30 )
or TTS Datamaster and Tunercat if you want to spend more.
Transmission: 5 spd
awsome .. thanks, that helps alot
got my camaro's timing / fuel pressure adjusted today and its running really nice right now ..
but im sure once i tune it .. then ill really have some power ..
