Rich/lean offset vs coolant temp info
Old Feb 11, 2008 | 07:07 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
What does it do? Looking for some more insight into how the ecm targets stoich and the meaning of certain terms.
Old Feb 11, 2008 | 08:41 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Rich/lean offset vs coolant temp info
In particular it shifts the o2 thresholds at different temps so you can run leaner when cold/hot.
In $8D
Will Subtract from values L84B4 (Window)
Will Subtract from values L84A2 (Upper Boundary)
Will Subtract from values L84AB (Lower Boundary)
The standard is that it only subtracts. I outlined a way to make it go both ways.
From the Tuning guidebook:
https://www.thirdgen.org/forums/diy-...ng-points.html
There's a spreadsheet that shows the relationships that are used in $8D that I made when first figuring it out. I used RBobs document to guide me through it all.
The operation is the same as the writeup by RBob on the 747 that is included in the thread.
Read it several times and then write it down in your own way and it will come to you. Took me several times to see how it all works. Then I made the spreadsheet to allow me to move values around and see graphically what was happening.
Jp
Old Feb 11, 2008 | 11:22 PM
bl85c's Avatar
Car: '85 maro
Why would gm even bother making this table? It makes such a small change to the target mvolt that it hardly makes a difference.
Old Feb 11, 2008 | 11:30 PM
bl85c's Avatar
Car: '85 maro
Edit- the file got screwed up somehow. I reloaded it and see how the table really works.
Bubbajones_ya
Jul 6, 2024 08:32 PM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
m00n420
Sep 11, 2015 02:39 PM
