Injector Constant - I need more scope on the VE tables
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
Hi all,
I'm working with the 8D 7730 ECM - Unfortunately a few of my values are maxed out at 99.61 and I can't get them any higher.
Now I belive that I'm correct in saying that if I make the injector cosntant smaller it will add more fuel per VE table reading..
here's what i was going to do....
Original Inj = 22.08lbs, New Reading of 18.01 = 18.433 % decrease
So if i use the Table Tool in Tuner pro and do a -18.43 on each table then it should run as it was before??
Can anyone see any problems with this?
Thanks,
Dan
Thanks,
Dan
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Re: Injector Constant - I need more scope on the VE tables
I run the 7747 w/ebl, but to get mre in the VE tables, you would raise the BPC, inessence making the ecm think the injector is smaller, there for giving it more fuel for a givin VE cell.
