92 Pontiac 3.8 V6 S/C, MAF tuning
Trying to finish my tune.
On a test drive the car runs ok when cold, (full acc and boost, no stuttering or popping.
Thr car has a new ecm, i have pinned out the ecm, check the harness and all senors that i have.
When hot it seems pops at wot back off just a bit and its good
As the car builds up to going wot the a/f is 12.0 and accels nicly,
push the pedal to wot and the popping starts. a/f is 13.5 and timing goes from 22-14.
i see that the maf khz is 127 when this happens. i went to that table and the top limit is 127.
i can only assume that i am reaching the top of my maf output table 6 as the numbers won't stay larger.
Is there a way to lift the limit of the tables?
Other things i have changed in the tune is shut off the egr as the car dosen't have this. set the timing tables to 0 for when it was on.
There are no cpu controlled fans so i set that high so it won't cause me any problems by tring to come on. i am receiving a quad drive fault a.
on this quad driver is the data dash (whitch i don't have)
low speed fan (no tin use,reason for turning off)
canister purge (car doen't have one)
and TCC brake switch (which i have to check to see if its connected.)
the last one here makes code 38 come on.
i have got the car to run better, seems not to have this problem when cold. which i am starting to belive is that the fuel is richer or the timing less or both.
Running moates chip and tunerprort software.
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 92 Pontiac 3.8 V6 S/C, MAF tuning
You should probably start by telling us what ecm and mask you're using.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
