Im lost
Car: 92 camaro
Engine: 5.7 tpi
Im lost
ok Someone please tell me this makes since.. I had my car tuned pretty good, well i dropped a valve , So i pulled the motor fixed the problem. Put the motor back the only change i made was, going from 8 degrees base timing to 6 degrees. The car ran great when you first started the car then when it went into closed loop it would start running real rough. Afr going in the etreme both directions and everyonce inawhile popping back throught the trottle body...................................please help with a idea someone because im all out Member
Car: 1989 Camaro
Engine: 383
Re: Im lost
Check all your ground straps. Mine acted crazy when I first put the engine back in and thats what my problem ended up being.
Car: 92 camaro
Engine: 5.7 tpi
Re: Im lost
i Call myself checking that, but you are so right thats exactly what it sounds like. I have checked them i know three times but i think im going to go tomorrow with a fresh mind and look again
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Im lost
run a scan to check out the o2 sensor, sometimes they don't survive engine work. Map vacuum line. maybe???
O2 and map are some of the few things that get used closed loop not open.
Car: 92 camaro
Engine: 5.7 tpi
Re: Im lost
thanks guys...I finally found it was in fact a ground. I took all of my grounds a loose and re fastened them to the block and it seems to have fixed the problem
ZZ3Astro
Aug 13, 2019 12:57 AM
3.8TransAM
Sep 27, 2015 08:37 PM
