Injector size
Old Mar 1, 2008 | 12:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Injector size
why does the 6E mask specify (static ?) fuel pressure for the injector size, and why 40psi and not 43.5?
Does the ECM base calculations on the static fuel pressure being 40psi?
Old Mar 1, 2008 | 08:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector size
There is nothing is the $6E mask relative to the injector fuel pressure. The code only cares about what the actual injector flow rate is.
As an example, if running 50 psi of fuel pressure (FP) and at that FP the injectors flow 30#/hr. Then the injector flow rate (constant) in the calibration is to be set at 30#/hr.
RBob.
Old Mar 1, 2008 | 09:17 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Injector size
This is what an ARAP.bin/6E.xdf in TunerProRT shows under Constants/Scalars for fuel injector size.
Old Mar 1, 2008 | 09:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector size
Best bet is to edit the xdf file and remove the "@ 40 psig" from those two entries.
RBob.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
