Granatelli w/ wb o2 sensor
Old Mar 30, 2008 | 11:14 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
Hi, just wondering , if a have a ajustable maf and a wb o2 sensors ; isnt it the easy way , maybe the best thing to do to adjust the afr of the engine itself ? ived try to burn chip but , it not that easy thing to do...
Old Apr 1, 2008 | 08:55 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Granatelli w/ wb o2 sensor
Setting the adjustable Maf changes the AFR at all air flows. A programed chip can be lean at idle, okay at cruise, and rich at WOT. Which way would you adjust up or down?
BTW this is what my car is with a stock chip.
Old Apr 1, 2008 | 04:22 PM
ok, so the best should be a adjustable maf ... if i can get the right afr at wot and at cruise and so at idle why should i bother me to make a chip ... maybe some one have a another idea about that...
Old Apr 1, 2008 | 11:22 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
If this were true there would be more adjustable MAF's and no use for DIY prom.
Old Apr 2, 2008 | 08:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a lot more to tuning a vehicle then just the AFR. Spark timing makes a huge difference in driveability and power. TCC lockup points, electric fan control, A/C control, and so on make or break the tune.
RBob.
Badass355ciz28
LSX and LTX Parts
Oct 2, 2014 01:33 PM
BlackenedBird
Nov 12, 2011 05:52 AM
customblackbird
Jan 28, 2011 05:19 PM
FranktheTank86
Jan 25, 2011 07:09 AM
mr iroc
Mar 26, 2007 09:02 AM
