has any one used the plx sm-afr to......?
Old May 2, 2008 | 05:32 PM
MuttlyTheWetDog's Avatar
Car: 87 s10 p/u The Wet Dog
Engine: 86 305 ho soon tbi
Axle/Gears: F8.8 4.56 limited slip
has any one used the plx sm-afr wideband controllers narrow band analog output for the computer? and used the the wide band analog output (0-5v) in the aldl data stream for dataloging afr
then hack in on one of the in unused inputs and use afr=2 x voltage + 10
im kinda new to tuning bun this seams the cheapest way to get wb o2 and not have to put in any more o2 bungs and also get real afr in to data logs along with narrow band readings for the computer to use and at less than $200
http://www.plxdevices.com/products/sm/afr/
Old Jun 10, 2008 | 12:20 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Re: has any one used the plx sm-afr to......?
I'm looking for info on the same PLX device, so.... "what he said."
Old Jun 12, 2008 | 01:39 PM
ty1295's Avatar
Yes I have hooked up both outputs, the 1 to simulate NB o2, and the true WB output.
Old Jun 15, 2008 | 03:47 PM
Engine: 305ci TPI
Anyone have any comments to compare this PLX wideband to the LC1 wideband? The LC1 seems to be the most used one around here, but the PLX looks and sounds like a nice unit.
ZZ3Astro
Sep 8, 2014 12:07 PM
TheExaminer
Aug 23, 2014 01:50 PM
MedVader
Apr 25, 2014 10:10 PM
jaweiss
Jul 23, 2011 09:58 PM
neat
May 26, 2005 03:37 PM
