Why change cylinder volume
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Like the subject says...why should you change the cylinder volume when going from a 350 to a 383?
I was out doing some tuning yesterday and got everthing fairly close. Then I noticed that somehow my cylinder volume got changed back to a 350 i/o a 383. I know I changed this before. This sucks.
As soon as I changed the volume back to 383 she started running rough again. I get to start over again.
Car: check
Engine: check
Transmission: check
Re: Why change cylinder volume
On SD systems the ECM needs to know the engine displacement. This value is used when calculating the mass of air that enters the cylinder. From that value (along with AFR) the ECM can then use the injector constant to calculate the required mass of fuel.
By using the cylinder volume of a 350 on a 383 the VE tables had to make up the difference.
RBob.
RBob.
Car: 92 GTA/ 00 TA
Engine: 383/350
Hmm. Thanks for the info.
Apparently I need to re-visit my spark tables as well.
This blows. Especially with thirdgen fest coming up this weekend.
Car: Death Mobile
Engine: 666 c.i.
Yes, you can tune the main VE tables and the P/E without adjusting the cylinder volume and have the engine run quite nicely - especially when the volume change isn't that great (like 350 to 383). But, you may find a lot of "other" tuning areas are affected (such as "pump shot") that also rely on this info somewhere in there calculatiosn and this results in poor drivability.
If you don't adjust the cylinder volume, you may end up having to do a lot of extra tuning to resolve those driveabilty issues. Whereas, if you change the cylinder volume, those issues may not even arise.
I say this, because in the past on "big displacement engines with large injectors", we had to trick the ECM into thinking it was a smaller engine with smaller injectors because there were some calcuation errors in the eprom (until they were fixed). And, once that error was fixed and the proper cylinder volume and injector size could be used, MANY of those driveabilty issues disappeared.
Car: 92 GTA/ 00 TA
Engine: 383/350
RBob.
RBob.
Grim - that may explain why i'm having a bear of a time trying to tune the 383 with a cylinder volume of a 383. My idle surge is back with the correct cyl volume. This was with the incorrect cylinder volume value.
On an interesting side note, I was able to eliminate the idle surge by knocking the closed throttle SA in the 400 & 800 rpm range down to 8 deg. from 20.
Car: check
Engine: check
Transmission: check
Then any thing that is done to increase the volumetric efficiency of the engine will also require an increase in the VE table values (cam, heads, exhaust, ...).
RBob.
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 31, 2015 10:47 AM
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:52 PM
