Ramjet Spark tables
Old May 26, 2008 | 08:13 AM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Ramjet Spark tables
Anyone have the ramjet spark tables?
Old May 26, 2008 | 12:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ramjet Spark tables
With the RamJet running Vortec heads the Vortec truck SA values are a decent starting point.
RBob.
Old May 26, 2008 | 01:12 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
here are some....
got them from a fellow on another forum...haven't done anything with them.
Attached Thumbnails Ramjet Spark tables-spark3600-6000.jpg   Ramjet Spark tables-spark6000-9000.jpg   Ramjet Spark tables-spark1200-3600.jpg
Old May 26, 2008 | 01:42 PM
Axle/Gears: 4.1
s_aujpv4 spark tables
..and here are the spark tables I've been using on my ramjet....I'm curious as to what s_aujp does about timing when above 5600 rpm?
On my Ramjet 350 the initial timing was 10 degrees.
When using s_aujpv4 I've been using 6 degrees.
It's running quite well right now; but I don't know enough to mess with the timing tables. I'm just slowly tweaking my VE tables to get BLMs closer to 128.
Attached Thumbnails Ramjet Spark tables-s_aujpv4-main-spark-table.jpg   Ramjet Spark tables-s_aujpv4-extended-spark-table.jpg
Old May 26, 2008 | 05:46 PM
rad8tion's Avatar
Engine: RAMJET 350
Re: s_aujpv4 spark tables
Thanks guys
Old May 27, 2008 | 12:20 AM
Axle/Gears: 4.1
and here's the lower rpm spark table....
Just got it from contact....I believe he'd sent it to me before and I'd lost it. I had previously asked about VE tables, but I guess the MEFI uses something called BPW....
And I have a question now:
If I wanted to compare my present s_aujp v4 spark tables to match these ramjet values; do I just add 6 degrees at each ramjet spark table point to compare that point with the same spot on the ramjet spark table (and add 10 degrees to the ramjet spark tables) at the same point?
Geez, I hope that made sense...
Old Sep 19, 2008 | 10:08 PM
banditvox's Avatar
Engine: 350 Ram Jet
These are my 350 Ram jet Tables.
Attached Thumbnails Ramjet Spark tables-spark-200_1200.jpg   Ramjet Spark tables-spark-table-1400_3600.jpg   Ramjet Spark tables-spark-table-3800_6000.jpg
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
