Questions about starting from mixed parts
Old Sep 1, 2008 | 07:17 PM
jstarnes's Avatar
Hello All
I have a project that has ended up with a few mix and match parts. The engine is a Chevy 350 with a bolted on tpi unit, all the stuff to eliminate the MAF sensor, a harness from s10wildside (Mike I believe) which mates to a 727 ecm. I have the autoprom APU1 from Moates.net with the cables to do real time and TunerPro RT
My main question is for direction as to which bin file to use with the ecm
from searching around there doesn't seem to me a ton of info on swapping to a 727 ecm, although I seem to remember one could use the same method as swapping to a 730???
Anyone care to throw a dog a bone
Jason
Old Sep 1, 2008 | 07:49 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Questions about starting from mixed parts
Naturally aspirated?
I'd look at using S_AUJP.
This is what I'm going to switch a friends truck to, that currently has a '7747 ECM installed, in gear idle and return to idle at a stop sign are giving me issues on his combination. I will be using a '7730 in this swap though.
His combo is a 365 (Smaller sibling of a 409), with a home made MPFI intake, TH400, true duals, in a '67 Chev pick up.
S_AUJP can be found on moates' fileman file sharing site. V4 is the newest version.
Old Sep 1, 2008 | 08:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by jstarnes
Hello All
Jason
You can use any BIN that came in the '7727 or the '7730. They are basically the same ECM. The '7727 being the underhood version of the '7730. Only need to pick a stock BIN to start with an go from there. The S_AUJP has changes made to it to provide additional functionality. It is also provided with an XDF file and I belive an ADS file. Which in itself is an asset.
RBob.
Old Sep 1, 2008 | 09:41 PM
jstarnes's Avatar
Thats What I thought I remembered, from reading here long ago
RBob.
I have also been reading this, , and as it looks I can DL it from moates.net/fileman
Jason
Old Sep 1, 2008 | 09:58 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Take a look at the latest version of the S_AUJP. It is version 4. There is a thread describing it here that is recent. As of today you want the 41026 version of the zip file.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
MENINBLK
Aug 5, 2015 11:58 PM
