90 350 HSR BLM 96?
Old Sep 14, 2008 | 11:48 AM
runningagain's Avatar
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
90 350 HSR BLM 96?
I am still having this same problem, I have corrected the idle and tryed many different bins. Could it be somethin mechanical? Has anyone had this probem?
Old Sep 14, 2008 | 01:00 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: 90 350 HSR BLM 96?
Triple check everything is set right both mechanically and electrically chip wise.
Fuel pressure, injector size, etc and so on
Old Sep 14, 2008 | 06:46 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
With tuerpro, what do you look at in the bin to see what the injector size is?
Old Sep 15, 2008 | 06:02 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I have 22lb injectors and foud out that the injector flow rate is 25.08, that would make a difference! I will change it to 22.08, Will this be correct?
Old Sep 15, 2008 | 08:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It would make a difference. However, no, that would cause the BLM's to increase.
RBob.
Old Sep 15, 2008 | 09:30 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
The blm should be between 132 and 126? I have 22 lb injectors, what should the flow rate be???
Old Sep 16, 2008 | 10:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You should set the injector flow rate in the calibration to what the injectors actually are. Or darn close to it.
If you lower the flow rate the PW will increase and the BLMs will go lower, if not already bottomed.
Who is doing the tuning?
RBob.
Old Sep 16, 2008 | 06:25 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
the prom was programmed by AFI, I sent it back once to be retuned, I still have a rough idle and blm's in the 90's. I talked to Kevin at AFI, he said they have'nt dealt with the holley stealth ram, could the tune be that different on a hsr than a factory tpi? I have checked all machanical so I am checking the tune on the prom, but I don't want to get into a BIGGER mess. I can't figure it out..
Old Sep 19, 2008 | 10:21 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I have plugs and wires comming tomorrow, will see if that helps. I was told that the iac counts should be at 20 at idle but the prom shows 160 at idle, will try 160 at idle, correct me if I am wrongh.
Old Sep 26, 2008 | 09:10 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I tryed pluges, wires, no luck. Now I have been reading stickyes from TRAXION, he talks about higher duration on a camshaft, lower vacuum and moding the lower ve table. My cam is .444 in, ex with duration @ .050 is 212 in, 218 ex lobe lift .2960 in, .2960 ex, lobe seperation of 114.0, with a holley stealth ram intake. Now I have tryed the S_AUJP_CCP_v2.BIN with the same, bottomed out BLM, is there a better bin to start with, from, or am I going with trial and error, I have a long way to go before I can mod any of this, I really need help!!!
Old Sep 28, 2008 | 09:54 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
I did more datalogging, TPS-.57, coolant-84.5c, MAP-1.84v, MAP-45.04kpa, AFR-14.73, O2goes from 84 to 937 and 255 crosses, INT is 121 to 126, BLM is 90, block learn cell is 5, injector pulse width is 1.5, IAC 0, spark/ TDC-14 to 24 degrees, spark/ ref pulse 9 to 19 degrees, I got a knock count of 7? This is at idle 700 RPM, seems the timming is irratic at best. I would like to know what to try next, thank you for all your input, I need to resolve this so I can drive.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
