Yes, more heated o2 Q's but specific...
Old Sep 23, 2008 | 10:52 PM
92GTA's Avatar
I'm going to be replacing my stock AC Delco o2 sensor with a 3-wire heated Denso o2 sensor because of my headers.
I plan on leaving everything alone in the PROM for the most part because I realize things like from a cold start the engine/oil/& coolant requires a variable enrichment before the car can be taken from open loop to closed loop and that it also gives the CAT time to warm up. Sure I could account for this by changing the commanded AFR at those coolant temperatures but in a not so modified engine, why bother when it works just fine now.
What I am specifically wondering about if the time it takes to enter closed loop when I start the car and it's already at full operating temperature, like the gas station or some other quick stop. What are the variables I can modify to affect this?
Most important to me is the fact that people here mention that when the engine idles for a certain period of time or you are coasting down a long hill, the ECM will enter back into open loop. Also that the ECM will not switch from open to closed loop after starting until you begin driving.
How can I ensure that the ECM never reverts back to open loop unless the engine is turned off and turned back on. I'm especially interested in this because I am up for smog and they tend to let the car idle for an extended period of time while doing the visual inspection.
Thoughts?
Thanks!
Old Sep 24, 2008 | 08:48 AM
devilfish's Avatar
Re: Yes, more heated o2 Q's but specific...
Never experinced that the ECM goes out of closed loop after installed a heated 02.
Regarding the time it will take for the car to re-enter closed loop after a shutdown, is depended on engine coolant temp and the closed loop delay timer constants. And yes, these can be changed. But you really shouldent need to.
