Transmission Flags
Old Dec 27, 2008 | 05:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Transmission Flags
Noticed the following yeaterday on a 22 mile return data logging hwy cruise.
Transmission Flags Status:
  1. 1st gear is always "FALSE" whether park/neutral is "NO, or "YES"
  2. Under 60 mph
    • 3rd gear = "TRUE"
    • 4th gear = "TRUE"
  3. Over 65mph
    • 3rd gear = "TRUE"
    • 4th gear = "False"
    • Overdrive request = "YES"
I can't image any condition where these combinations are possible.
Can someone shed some light on this?
Old Dec 27, 2008 | 08:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Transmission Flags
Didn't list which ECM and maskID is in use. However, with f-body's and the 700R4 only hi-gear status is sent to the ECM. The Park/Neutral is a switch on the shifter. So even with the engine off and key-on the prk/neut indication is sent to the ECM.
Back to 4th gear. This is a pressure switch within the transmission. This switch is either NC or NO, dependent upon the application. So it very well may be that the wrong switch is in the trans (for the app).
Note that most (all?) GM MaskId's have a flag to define which 4th gear switch is in the tranny. So if the opposite is reported by the ALDL, then a flag change will correct it.
Note that this also affects which TCC lock/unlock tables are used within the ECM.
RBob.
Old Dec 28, 2008 | 12:05 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
'165 ECM 6E mask.
Diagram shows TCC relay contacts for 4th gear signal as NC.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
