need help deleting my knock sensor
Car: check
Engine: check
Transmission: check
Re: need help deleting my knock sensor
Usually all that needs to be done is to un-check the DTC 43 flag and zero out the maximum allowed retard tables. Can also set the CTS threshold high just to be sure.
RBob.
RBob.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you sure its false knock? Removing the knock sensor while you're getting real detonation is a good way to ruin an engine.
FormulasOnly
Sep 10, 2015 09:07 PM
