Help get this freakin ape off my back!
Old Jan 28, 2009 | 11:16 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
My ecm is clamped to a max INT of 128 in drive. The INT will move above and below 128 just fine at idle, but when it's lean in drive the int will climb until it hits 128 and stop like it's hit a ceiling.
It seems to have started when I switched to an analog tbird maf. I've checked out all my grounds, connected and disconnected various inputs and messed with the calibration 'till I couldn't come up with anything else that would be remotely related. I had something similar happen before where it was clamped off at idle- turned out the O2 switchpoints were off but that's not the case this time. I haven't had as much time to mess with this as I normally would but I'm hellbent on getting this straightened out.
Old Jan 29, 2009 | 01:23 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: Help get this freakin ape off my back!
Is your LV8 load being calculated correctly? What mask and bin are you using? Are they posted anywhere?
Old Jan 29, 2009 | 03:51 PM
bl85c's Avatar
Car: '85 maro
I'm running $6E & my own custom bin based off arap. When I get home from work today I'm going to post a datalog showing what's going on and a copy of the bin I'm using right now. Load calc's look fine.
Old Jan 29, 2009 | 09:47 PM
bl85c's Avatar
Car: '85 maro
Can't get the website to load the files properly so I have them at moates.net. Bin's in the custom modified bins section under 2.8 \'165 ecm (E).bin and the datalog in the datalogs & tuning notes section under 2.8 \'165 ecm (B)6.adl.
Old Jan 29, 2009 | 10:49 PM
Try changing 4E3 (decel causes INT reset if LV8 <= this) back down to LV8=40. Now it's set to 255, and my be resetting your INT while driving.
Just a guess...
Good Luck,
Old Jan 30, 2009 | 10:52 PM
bl85c's Avatar
Car: '85 maro
Aha, it was staring me in the face the whole time, I just didn't see it. I had 4E3 labled as enable decel enlean if LV8 below X. Thanks again.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
