8D Highway Mode Spark for a 454/TH400
Old Feb 1, 2009 | 09:45 AM
dave w's Avatar
I using the 8D bin for my 454 / TH400 MPFI engine. I was wondering how I should program the Highway Mode Spark. I am using TunerPro and a Moate.net Burn2 Prom Burner.
The TH400 does not have a 4th gear or a Torque Converter Clutch. Is there a Constant(s) / Scalar(s) or Flag(s) / Switch(s) I should set / unset?
I've attached a screen shot of some of the Highway Mode Spark Constant / Scalars.
Thanks,
dave w
Attached Thumbnails 8D Highway Mode Spark for a 454/TH400-454-highway-spark-mode.jpg
Old Feb 3, 2009 | 05:15 PM
???'s Avatar
Re: 8D Highway Mode Spark for a 454/TH400
do you have a vss hooked up?
if so, it would be used like normal. there's not a 4th gear flag that i know of. just set the mph you want it to go into highway at and the min coolant temp.
if not, then i think i saw a thread somewhere of a guy that run it with no vss, but i don;t know if it worked. something like mph set to 0 and used the timer to delay it a while before it kicked in.
Old Feb 3, 2009 | 05:47 PM
dave w's Avatar
Thanks for the reply. No VSS yet. I'll do a search for posts 8D not using VSS. I'm sure someone has an 8D without VSS? Then I'll see what I can figure out from that information. Any suggestions on an aftermarket VSS, I might go that direction at a later date.
Old Feb 3, 2009 | 05:53 PM
???'s Avatar
i don't know what the easiest way to add a vss is, but i do know there's a very long thread about adding vss to a th400, or something like that.
here's 2 quick links i found
https://www.thirdgen.org/forums/diy-...e-without.html
https://www.thirdgen.org/forums/diy-...-settings.html
from what i've read. the vss is a pretty big deal. lots of drivablitly things are based on it. so it may be worth your while to have one.
Old Feb 4, 2009 | 03:06 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you defiantly want to get the VSS working, otherwise you'll be banging your head on the wall trying to get it tuned right.
without a good VSS signal, the ECM will be stuck in idle cell 4.
before playing with hiway mode, you need to have your fuel and spark tables pretty close which you can't really do with it in cell 4.
there are also some other things the ECM needs the VSS signal for.
Old Feb 4, 2009 | 10:08 AM
dave w's Avatar
I think I'll order this VSS http://howellefi.com/customer/produc...1&cat=0&page=1
Any other options for a VSS?
dave w
Old Feb 4, 2009 | 01:31 PM
???'s Avatar
dave w
i like that looks simple and to the point.
double check the ppm output. your ecm is looking for 4000 ppm. it can be adjusted in the ecm but it may make life easier if its 4k already, or is adjustable would be even better. that is if you plan on using the speedo output from your ecm to a stock speedo.
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
