Where to buy a tuner pro or pocket programmer?
Old Feb 19, 2009 | 06:19 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Im looling for a pocket programmer to be able to plug in and watch all the sensors anyone know where to buy or find one?
Old Feb 19, 2009 | 10:20 PM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
Re: Where to buy a tuner pro or pocket programmer?
You may find what you need on ebay.
Old Feb 28, 2009 | 09:08 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
A pocket programmer won't let you see the sensors, only change the Eprom.
You need to read up on Aldl cables (OBD 1) to a laptop, to get sensor data.
Old Feb 28, 2009 | 09:32 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
As pointed out you're asking about the wrong item.
A Pocket Programmer programs EEPROMs.
What you want is an ALDL cable.
Several are available.
I use an ALDU1+CABL1 combo from www.moates.net, when I'm in a vehicle.
I use a home made serial (MAX232 based) ALDL cable on my test bench.
There are other's available through aldlcables.com, and a couple other places that I'm not recalling at the moment.
I would suggest getting an USB based cable, since many newer laptops don't have serial connectors, and if you ever need to borrow one or buy a new one, this will make the switchover easier, if you have a laptop that has a serial connection now. USB to serial adaptors are flaky at best. I have a couple adaptors that worked, but now I can't get them to connect, and nothing has changed.
I ran into a port compatability issue last year, not with the ALDL, since I already had the ALDU1, but I had to buy a new programmer since I was using a parallel based programmer, and the new laptop didn't have a parallel port.
Old Feb 28, 2009 | 02:25 PM
Car: 86 Iroc-z
so the pocket programmer will let me make changes to the computer?Or what will it allow you to make changes to and where would i find one of those? thanks
Old Feb 28, 2009 | 04:26 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
See here https://www.thirdgen.org/promintro
Please read
F.I. 57 Belair
Aug 23, 2021 01:09 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
ericjon262
Sep 11, 2015 06:07 PM
Kenwood
Sep 11, 2015 12:50 PM
85Special
Sep 3, 2015 04:21 PM
