Data/Logging help
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Data/Logging help
Hi ,I would like to ask a question, I Just purchased a "Moates" cable and Am using TP/RT. I can record data and play it back. Everthing works very well.
I USED to have Diacom on another computer and when i recorded a session and opened it up in excel the MAP, BLM, RPM where very easy to work with and make corrections to. Now that i no longer have this HOW do i go about comparing my BLM's and making changes when i no longer have excel?
My new lappy runs Vista with a program called quattro pro, it is very similar to excel but not.
So long story short, How do you compare data and make changes to the ve and spark tables using TP?RT data logging? thanks GTA.
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: Data/Logging help
after you are done data logging with TP RT you have to export the data file as a .csv file. Thats a pretty generic file type and my guess is that Quattro should be able to import it.
