hot start issue
Old Apr 9, 2009 | 06:54 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
hot start issue
takes 3-4 tries to get the motor to turn over when hot after cam swap. will i get quicker starts with more crank timing or adding some fuel?
Old Apr 9, 2009 | 11:29 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: hot start issue
Does the motor not turn over?
or just not start (takes 3-4 revolutions)?
If it doesn't turn over I would suspect the starter solenoid is getting hot from the headers. Get a heat shield on there to save it from cooking.
If it takes many revolutions to start then it could be the warm park position for the IAC needs to be changed. Not enough causes hard cranking, too much freewheels but has too much air.
Adding/subtracting fuel would depend on that setting.
HTH
Old Apr 9, 2009 | 01:45 PM
scottydta's Avatar
Car: 1989 Trans Am
Re: hot start issue
motor is turning over but doesn't catch. it hippups sometimes leading me to believe it needs more fuel. i'll try adding some park steps and see wht happens.
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
