Final SA - Patch for ANTS
Old Apr 14, 2009 | 09:04 AM
BlackZJ's Avatar
Hi!
I want to patch my ANTS bin so I can log the final SA and SA retard.
Somewhere on the net, I read that one could apply a patch without dissamble the bin. Is this really possible?
If not: Has someone already dissabled this bin file? I'm having problems, to get this to work...
Mat
Old Apr 14, 2009 | 10:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Final SA - Patch for ANTS
Go over to the TBI board, up top in the sticky's, Come In For A Free Tune thread. In there I posted the locations to change to put the SA into the ALDL stream. Same for putting the injector PW into the ALDL stream. That along with the math to convert the ALDL stream values to real world values.
Note that in the Patch Method Demo thread (see Tuning Guide Book sticky ion this board), there are patches to change the speed limiter to a rev limiter and a code 43 forced knock test bypass.
RBob.
Old Apr 17, 2009 | 06:37 AM
BlackZJ's Avatar
Thank you for your reply, RBob!
It works now. But what is $61 and $62 exactly? Total Timing or a value from the "Main SA" Map?
What address is used for SA Retard?
Thanks!
Mat
Old Apr 17, 2009 | 07:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
$61/$62 is the timing as programmed into the distributor. Which means that the iniitial has been subtracted out. And needs to be added back in.
SA retard is in $6D
Use the same conversion as for $61/$62, but then divide it by 2 (half the amount). Or just use 45 / 256 (.176) as the multiplier.
RBob.
Old Apr 17, 2009 | 07:52 AM
BlackZJ's Avatar
OK, thank you!
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
