Can I keep it alphabetized?
Old May 30, 2009 | 11:31 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
I 've been working in TunerPRo RT with the S_AUJP_ V4 files and bins.
THe lists of constants , flags and tables are jumbled. I've been trying to make them alphabetized, then saving both the bin and XDF file.
If I don't turn off the computer it's stays alphabetical.
As soon as I turn off the computer, the next time the program is opened it will be all jumbled again.
How do I KEEP in alphabetized?
Old May 30, 2009 | 11:51 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Can I keep it alphabetized?
AFAIK, It won't stay that way but all you need to do is click the Grey "item Name" to sort them each time you start TP. (That's in the Item summary List)
Pretty much all I ever use when viewing the items. You can sort by address, type or name in that view easily.
Use the "Find" function or the catergories to make "sets" of things to work with.
Old May 30, 2009 | 02:06 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Odd, I have no issues organizing the xdf items in the orders or under headings when I do.
Just save the XDF with a unique name. I.E. "S_AUJPv4sort.xdf" It will then save in the order you have organized it. When you save it as the orginal file name I have noticed that it may not save the changes you have made. This applies to bins as well, save as a unique file name each time.
You don't need to save the bin when you change the xdf, they are not related that way. The xdf is basically just a road map to what is on the bin. The bin is not changed when the xdf is.
jraider66
Car Audio
21
Sep 4, 2015 07:52 AM
camaronewbie
Car Audio
Apr 7, 2012 12:36 AM
Ron U.S.M.C.
Jan 17, 2012 09:17 PM
tommygun
Oct 4, 2002 08:45 PM
